Hi I’m hoping someone can help. I have the Brandon Lee theme Couture but I just can’t actually get a banner to work. These are the instruction;
Open your page inspector and locate the Banner Area and the Number of Slides options.
Simply select the following options: Static Image / Texture / Color (Static Image Enabled)
*Ensure that the “None (Static Image Enabled)” option is selected under the "Number of Slides (Slideshow
- Copy and paste the following code into your sidebar area with the name of the image you have dropped into your Resources area. Example: The page will display banner_1.jpg
<div id="fs"><img src="%resource(banner_1.jpg)%" alt="My Image"/></div>
So I have done all of that - I have named my image banner_1.jpg I have put it in the resources. I have copied the code into my sidebar. I have set the controls in the page inspector as instructed.
All I am getting is a no banner image plus a small blue square with a question mark in it. Thats it!
I have read and re-read the instructions tried every combination and still no banner. Can anybody help me hear - I have written to the developer - It seems this theme does not work as advertised - and anybody help?
many thanks!
