Machist
(Olli Ovaskainen)
17 December 2015 07:47
1
I Purchase theme:
http://rapidweaver.kloudstores.com/product/bootclean-responsive-rapidweaver-theme
In preview “Full Width” you cannot see header image?
But if you change “iPad Portrait” then header image is visible?
the same problem also applies to background images, colors etc.?
Any ideas what is wrong?
I use latest Rapidveawer 6
Machist
(Olli Ovaskainen)
17 December 2015 19:49
2
Fixed: disable the RapidWeaver Consolidate CSS File setting within Preferences.
Turtle
(Brad Halstead)
24 December 2015 18:56
3
@Machist
Thanks for providing the fix and resolution to the issue, will likely help others. Was it in the Theme’s tutorials?
Brad
Machist
(Olli Ovaskainen)
24 December 2015 19:43
4
I Googled and found this: http://michaeldaviddesign.com/themes/paramount/tutorial/index.html
“If you are experiencing any display issues with the theme, or if certain style options are not working properly, please disable the RapidWeaver Consolidate CSS File setting within Preferences. The disabling of this setting should restore your style option selections and display issues.”
This fix issues also other templates…
Turtle
(Brad Halstead)
24 December 2015 21:05
5
@Machist
Very nice, thank you for showing your path to resolution of the issue.
Brad
