Can not move from View to Edit mode - Solved
RW8 RWSkins Mojave file will not move from VIEW mode to edit mode. I checked the similar past topics and yes, I did try to bring in blocks 4 but I did not do it correctly and do not know how to delete it.
My previously saved file of this site has issues so I can not go back to it. I’ll remedy that after this is fixed to save a copy that works.
I moved from the theme flood theme Mountains to skins and it shows skins under themes but what is showing is Mountains.
Sorry, I messed it all up !! Thanks for helping! and happy new year!
Not sure I understand what you are saying is going on.
If you can’t select edit mode, make sure you are not on Master Style and are on a page.
I can’t see anything about Master Style. Since I am only in View mode, I do not have a left column to see or select anything.
You should be able to view the page list even in preview mode.
Try ⌥Opt+⌘ Cmd+L or View menu>show page list or the Inspector button:
2020-12-31_14-03-41
Ah, the keystrokes did it! Yes, in master style. I will note those. Many thanks.
Also, where can I learn the basics of using stacks? I assume they can be integrated with a theme, not used just alone?
I have too many years since using the RW program, hopelessly out of date and brainpower.
You saved me!
Here’s a good starting point
https://blog.realmacsoftware.com/getting-started-stacks-rapidweaver-8/
Many thanks for your assistance!
I see that I ought to put Solved on the subject, but I can’t see where to do that.
You should see a little pencil icon on the original post. Just click that and it should let you edit the title:
2021-01-02_12-06-22
