Can't Add Hex Code to add Color
I want to create my own color pallet, but I can’t do that easily by pasting hex code. Actually I have to use the color wheel to try to pick the color at the screen. Not efficient.
If we could just click at the code and change it, that would be heaven.
Hello. If you click on the colour sliders button next to the colour wheel, you will be able to type in your Hex code. Hope this helps.
Yup, @aku is correct! You can find the hex input here…
