Using Hex colors
How do I choose a hex color? All I can find is the extremely limited RW colors in different forms and none of them will show the hex color so I can match my branding. I’m trying to redo a website, that I used to use Adobe Dreamweaver for. I don’t have to make the site exactly the same, but I would desperately like to match my colors to the ones I used before (like in my logo designed in Photoshop). How can I just tell Rapidweaver I want to use color #3aadd0 ?
Thanks in advance
Hi Jo,
It might depend on where you are trying to change the color.
Must of RW uses the standard Mac color picker. If it’s in a theme or a stack, there are options in the inspector to set the color.
You click on the color selector:
That will launch the macOS color picker. Select the RGB slider and enter the hex code:
Thank-you!!!
