You should use that code. With additional #intro
!important is not necessary.
#intro #intro-background { background: url(%resource(your-image.jpg)%) no-repeat center center; background-size: cover; }
One complication here is adding banner images to sub pages in Split theme (any page not on root). You need to ad ā¦/ just before resources
So top level (root) should be: url(resources/
1 folder down should be: url(ā¦/resources/
2 folders down should be: url(ā¦/ā¦/resources/
And when you do this, the banners wont show in preview - they will however when published!
Itās not necessary to do this.
I see all banners in RW preview without this code.
ā¦ and RapidWeaver does this itself, automatically.
Here in a sub page
ā¦ and here in a main page
Sorry I should have looked in more detailā¦ your code is better than Yuzools on the āhow toā page. ! Wish Iād seen this before - would have saved me some head-scratching and time! Thanks
There really does seem to be a lot of confusion about how to manage custom banner images in the Split theme doesnāt there? I wonder how much of it stems from the use of a hard-coded path in the early snippets (rather than using the resource macro?) Not sure.
Thank you for pointing out that the Yuzool page isnāt as helpful as it might be. Thats something Iām going to fix right now, as in tonight.
https://www.yuzoolthemes.com/support/article/view/themes/split-theme-banner-images-101
Any better?
Full credit to @Oscar for the snippet and @manofdogz for pointing out the gap in the knowledge base.
Thank you for the honor @manofdogz @kryten
Here another post on this subject.
@Oscar
Awesomeā¦ Now Iām considering whether I should make a stack for Split just to simplify the myriad of possibilities. Weāll see.
Hi Oscar
Thanks for your help in January.
Ive just put a new drive in my mac and cannot work out what files to copy over to get my āTesla Copyā theme to work.
Can you remind me please
Lee
@CountryGent
Hi Lee,
do you have still access to your old hard drive? Do you have RW6 or RW7?
Cheers, Jannis
Thanks for getting back to me.
Ive RW 6 now and will likely upgrade in the near futureā¦
Cheers
Lee
Again, do you have access to your old data on your old hard drive to copy the theme from?
Sorry dude yes i do, its plugged in on a cable right now
Well, the you have to navigate to the same folder on that hard drive, where the themes are placed.
http://cafe.yourhead.com/?qa=50/how-can-i-find-the-addons-folder-in-rapidweaver-6
Thanks, sorted and Iām up and running.
Much appreciated Jannis
Thanks for the advice here, allowed me to change the banner image!
One questionā¦
Iād like to banner to be smaller, really I mean thinner, as it is now someone visiting the site gets 60% of the picture and needs to start scrolling ASAP.
Is it possible to resize it?
Hi there,
Using RapidWeaver 7 on a Macbook Pro with OSX El Capitan:
I copied the CSS code
#intro-background {
background: url(resources/newheader.jpg)
no-repeat center center!important;
and put it where it goes. The new header shows up in RapidWeaver but NOT online after I publish. It just shows grey.
When I upload the ānewheaderā I can see the file called ānewheaderā actually uploading. Yet, the finished product shows only a grey background.
See screen grabs.
Any advice?
Thanks.
So I tried adding the āā¦/ā just before the word āresourcesā to no avail. What worked is the following, which is listed above by manofdogz.
Works like a charm. Thanks!
Thanks for the info guys. I changed my banner image. had to make it a bit darker to work out, but itās there.
I know this isnāt official RW support - but for a drag-and-drop editor, having to insert CSS on every page just to change an image seems like such a kludge? or is this just a way to get you to purchase other themes, which might be more editableā¦
Iād love to find a way to make the overall banner a bit smaller as wellā¦
Thanks @johnmcboston - in RapidWeaver 7 thatās now possible with a new feature - banner replacement - which is added in any RapidWeaver 7 optimised themes, like Kiki or Voyager - which ship in RW7
