Dear Oscar, I have two major problems with Tesla Pro.
I have managed to add my background as describen. I would like to insert a link on the Logo or on the picture which I know put as background. How can I do that?
When I click on the menu bottoms the background should go up, so that the Menu remains on the top of the page. This doesnt work. I have to first click on the menu item, them click on the arrow below the logo to scroll down. Is there a way to let this happen automatically? Thanks!
Cristiana
As @instacks points out, including a link on the background image for the banner is not an option of the theme, whether youâre using the free version of Tesla that comes in RapidWeaver 6 & 7 or the paid Pro version that I sell.
As for the navigation in the theme â The navigation is not designed to work in the way you describe. The theme does not automatically scroll down to below the banner when a visitor lands on a page after clicking a link within the navigation bar.
I have been following this thread for a few months now but the banner I see on the my preview is not visible when I publish the website. I was using the old code: #into-background {background: url(resources/header4.jpg) no-repeat center center! important;} and I was able to see my banner in preview. I have since used the new code but as soon as I preview it, my banner disappears and the Split background shows. Any suggestions would be appreciated.
I think youâre going to have to either
1.) modify the index.html of the theme and republish or
2.) modify the published pages either manually or by batch using find/replace with something TexFinderX
Ready to do that, it sounds complicated. I am actually not so good in that. I would try to modify the index first. Where can I do that? SorryâŚit is a small nightmare
Thank you so much for getting back to me. After three long days, I finally figured it out. I was focused on the code but it turned out that the size of the photo was the problem all along. Live and learn. Thanks again for your help.
Hi there - for me it was a upper- lower case problem in the filenames.
I changed the filename.JPG in filename.jpg and it also worked after publishing to FTP.
Same for me. I just tried switching my whole site to SPLIT, and this is the one last thing I need to fix. In my preview window withing RapidWeaver, it shows the image I have in my RESOURCES, but after publishing, I just have a dark grey banner where the image should be with the white text of my site name on top.
