I am using RW8 with Foundation and in this specific circumstance I am using the beautiful Chroma Stack by @tav
As you can see in my blog article page , I have used the Chroma Stack to fix the blue side-banner, so it keeps company the reader throughout the whole article.
I’d love to have the blue side-banner to disappear once the user scroll down the green banner with the CTA.
Any idea on how to do that? Do I need Chroma Pro Stack to do that?
The easiest way would be to use Sticky Grummage instead of Chroma, this will stick in a column and so when the end of that column is reached SG will scroll up with the rest of the content. https://www.bigwhiteduck.com/stacks/stickygrummage/
I have also tried to equalise all the others… but they don’t have an effect on Sticky Grummage Stack. So, then I de-selected equalise to all, and just kept the Equalise setting to the 2 column… I am not sure why it’s not working.
I don’t have to do anything fancy inside GS, right?. The settings looks very easy and seems I have to do nothing for it to stick
Make sure that the Sticky Grummage is directly inside the column - i.e. not within another stack.
Here is a little example, I’ve placed a non sticky paragraph and a sticky paragraph in column 2 so you can see it in operation similar to your page. https://apex.d.pr/f0pBHK
