Classifieds page made with Rapidweaver + Foundation?
Do you know how to write PHP?
you mean like coding in php language? no. sorry.
Yes, that is what I meant.
If you would like, you may email me at jmunson at twobrothersit dot net and do one of two things - either send me your UID/PWD/Server/DBName/TableName (split the PWD and DBName into a separate email), or just an email requesting a piece of PHP you can modify to check your server to see if it is being found.
I will either write a piece of PHP and test the connection for you, OR, send you one you can modify depending upon your choice above.
writing your email right now. :smile:
I have your note, I will get back to you soon as I’m on another bug hunt at the moment… :wink:
thanks. anything else you need don’t hesitate to ask!
Here you go.
It is a work in progress and i haven’t done anything to it for a while.
thanks a lot man! this will help me so much to understand the Stackapps and the SQL logic!
I just came across this post while looking for a way of using classifieds myself, and when I clicked on the link for the ‘HospitalityEmployee’ zip file, it’s no longer active in DropBox.
bitbumbpy, could you please repost the link so I may also look at the RW file it was created with?
If you can, it would be much appreciated. Thanks
Sure @design4film , here you go. (I did a bit of a summer clean out and moved some files around…)
