Clean Menu - add to every page
Dear Gurus
I am very happy with Clean Menu by 1LD.
The tutorial suggests that the toggle (Hamburger?) might display on all sub-level pages but it doesn’t. So I am stuck with only the landing / index page having a menu. people who visit our site need to use the back arrow to navigate our site. Can the Clean Menu be extended to all pages in our site?
Thanks in advance
Richard Riley
www.WASHA.org.au
Just make a Partial of the Clean Menu stack, then copy that partial and paste it on every page on your site. This way when you make changes to the settings of the Clean Menu stack these changes are immediately reflected on all other pages.
I never knew there was an included theme without a built-in menu. It was likely intended for a one page site. @rhriley it should be fine once you add the menu to every page As @RapidBase says, just like you would if you started with a “blank” theme.
Clean Menu is an excellent menu stack, which I also use.
Thanks Chuck. There was a side-bar menu which I needed to hide to avoid having the Clean Menu and the inbuilt menu at the same time. I needed help to hide the inbuilt menu which did appear on every page, but now I need Clean Menu on every page. These issues are keeping me interested.
Richard
Dear Clean Menu Gurus
Recently my Clean Menu stack stopped working. It does not seem to picking up the menu and has reverted to the default Latin setting. Not sure what has happened since it is not a stack that I have tampered with.
Hey @rhriley,
Have you tried re-publishing all files? Usually, this type of behaviour is caused by a missing asset.
Erwin
Thanks for your suggestion.
I tried re-publishing and unfortunately that didn’t solve the issue.
I decided to exit RapidWeaver and re-start it. Then I saw the warning that I needed to re-install Clean Menu. Somehow the Clean Menu stack was corrupted. Reinstalling it fixed the issue. The Latin was replaced with page headings. :grinning:
Good to hear it resolved itself, @rhriley!
Erwin
