I am using Lander theme in default and have been happy not to need to add any code. However the lines of text on one of my styled text pages would look better in single spacing and the default seems to be double spacing.
Can someone please tell me CSS code to change default double spacing to single spacing.
Thanks so much for your help Doug. Don’t know what I’m doing wrong - I’ve entered that piece of code into the CSS column in the Inspector but it doesn’t seem to alter anything. I tried a few different heights … 1.1, 1.0, 0.5 but it still stayed the same.
Thanks so much Doug - the second piece of code worked a treat. I’ve now added it to all my text pages and I think they look a lot better. I love the Lander theme, it’s exactly the style I was looking for, it’s so simple and straightforward for someone like me who knows nothing about creating websites! but the default line-spacing was just a bit wide.
Hi guys! I will greatly appreciate any help regarding the same subject: is it possible to change line spacing for one or several specific text stacks only, instead of changing line spacing for the whole website? Thank you!
The website is www.nyllaw.com At the bottom, I used the 2 Columns layout from the stacks library to separate the logo (on the left) from the disclaimer (on the right). I want to change the line spacing in the disclaimer, to make the space between the lines smaller. Thank you!
May I ask you one more question? My website has three versions - English, Russian, and French. I used the code for the English version, and it worked well. I tried using the same code for the other two versions, but it wouldn’t work. Do you think I need to change something in the code to make it work for the other two versions? The respective links to the other two versions are in the right upper corner of the home page - nyllaw.com Thank you very much!
