I have a two column Foundation stack and I would like to make one column bigger than the other and I can’t figure out how to do it. Any help is appreciated.
Down toward the bottom of the stack UI, you will see setup areas for mobile, tablet, desktop. Each of those areas let you select from 1 to 12 units for each column. Note the total of the two should be 12 if you want them side by side instead of stacked
Have you seen this? https://foundationstacks.com/learn/the-grid/
Thanks for the help
