Contact form does not work with PHP 8.2
Hi, unfortunately the contact form in RW does not work. I use RW 9.2.1 and the PHP version is 8.2.
Do I have to downgrade to PHP 7.4. ?
Thanks,
Frank
Hi @aguaparami,
Could you clarify what “not working” means for you?
We are aware there is an issue with the built-in Contact Form when being used on PHP versions 8.x, however that issue doesn’t prevent the form from sending, the notification emails just come over a bit malformed (still readable, it just includes some raw code).
If you are experiencing a different issue, let us know exactly what that is so we can advise further. We do have a troubleshooting guide I recommend checking out, as it might help to clear up any deliverability issues you might be experiencing.
