Hi just swapped over to rapid weaver 7 contact form will not work hosting site is by host papa been on to them it sends to server but comes up with error there tech guys can not configure it help needed
Without a link to the offending form and the settings you’re using, it’s impossible to help you.
its the standard form that comes with rapid weaver contact us all filled in correctly the issue is host papa do not do php mail script
Ah, time for a decent host maybe.
no haven’t upgraded to stacks yet is that in the standard stack package
First you’d need to buy the Stacks plugin that comes with some basic layout and other stacks, but then you can get many more stacks from different vendors to extend RW to do pretty much anything.
The contact form from Doobox would be an extra purchase after you have the main Stacks plugin.
Hi bought stacks and doo box still will not work very dissappointed my host still says it needs codes added but there is no box when I wrote site originally in serif x8 they had a proper box to fill in worked first time so much for plug and play
You get what you pay for in regards to hosting. I learned that a long time ago.
The usual tactic of hosting companies is to blame either the user or the software. It covers their own cluelessness.
Good luck and a very Happy New Year
What is a good host for RapidWeaver
It depends. Are you aiming your site at a particular audience in the UK, US or another country?
It also depends on your budget.
A2 hosting is used by Realmac. I’ve used Hostm before, based in Germany. I only switched from Hostm because they don’t do reseller hosting.
I think A2 has a choice of locations so you could choose Amsterdam if you’re based in Europe.
