I have two sites both of which use the Foundation theme. I’ve developed a page on one site which would also work well on the other with limited modifications. It occurred to me that there must be a way to move an entire page between sites if they both use the sam theme and have access to the same stacks. I just can’t quite figure out how to do it. Standard copy/paste doesn’t work. Is there an answer for this or is it just the way things work?
Just drag the page from one doc to the other
And it works. Many thanks.
