Had a report from a user of stock banners missing in the Geometric theme when CSS Consolidation is disabled.
The theme sets a javascript variable in the index.html
using %pathto()%
to reference a banner image file in the theme. Then in a javascript theme variation I set the image source of an <img></img>
tag using this variable. It is done this way because I needed an actual image tag vs setting the background of a div
for the banner. I’d previously used the developer community’s RWSetGet to do this, but the new Cache Busting feature busted that, so I went to this method.
That being said, I’m not sure why CSS Consolidation would be affecting whether this <img></img>
works or not since it isn’t in a CSS file at all.
Here’s a link to the theme: http://d.pr/f/Jlf7
Let me know if there’s any other info you might need.
