I’m trying to apply a custom theme to the Storm theme (or any theme for that. matter) and when I reveal them in finder and try to install them they don’t show up as a custom style in Master Styles. If I try to reinstall them RW says that they are already installed.
Can anyone tell me what the problem is?
willwood
(William Woodgate)
13 February 2019 12:31
2
How are you installing them? Are they going into the correct version / location of RapidWeaver?
I’d always recommend dragging and dropping them onto the RW dock icon.
Double-click installs are not as reliable as they once were for any RW addons…
This is how I’m installing them Will.
the last screenshot is what I get when I try to install the custom style. Then when I try to apply the style it isn’t there. I’m at a loss.
I figured it out. Once I changed a couple of things in the theme then used the dropdown my custom style showed up. I have no idea why.
system
(system)
Closed
16 March 2019 05:37
5
