I recently added a theme to RW, but it doesn’t show up in the themes browser for me to select it. It says it’s installed. It’s in the add-ons theme folder, but it is not listed in the themes browser. Does anyone have suggestions on how to get RW to remedy this so I can use the theme? Thanks.
Nope. It doesn’t show there either.
Which theme was it?
And restarted RapidWeaver?
Natural from WeaverThemes. The stacks that came with the theme are in the add-ons, but not the theme.
I’ve restarted and reinstalled many times. I even tried it on my old copy of RW7 with he same results.
This is an old theme. Originally RW6. Which RW version are you using? I don’t have the theme myself and unfortunately can’t help. Maybe write to the developer to see if the theme is still up to date.
Can you use the “Reveal Addons Folder” option in the RapidWeaver menu and check if the theme is in the “Themes” folder (see screenshot):
I have RW7.
I’ve written to the theme creator and am awaiting a response. I just thought I’d check here in the meantime to see if that had happened to anyone else.
Yep. I’ve checked there and it’s there with all the other themes.
I’m wondering if the theme got corrupted during download so RW can’t load it. Feel free to send it over to us and we’ll take a look - dan@realmacsoftware.com
Dan, just emailed you. Thanks for taking a look at it.
Can you resend as it hasn’t come through
