Default theme question
Maybe I am going blind…how do I change the default theme in RW8. In previous versions I could set the default theme in Preferences > General…but I do not see this option in RW8. Help!
Hi!
Hope I understood correctly what is missing and this helps.
Hi there, as above - open the theme dropdown, then right click the theme you want and select ‘Make default’ :sunglasses:
Thanks so much! I wonder how many other Easter eggs I’ve not found!
Thanks so much!
