Are any of your classes inheriting from RMModelObject
? If so, you’ll want to read this.
As of RapidWeaver 7.3.1 (release date TBC), RMModelObject
will be officially deprecated. This means that at some point in the future it’ll be going away.
In every case where we’re using this class in RapidWeaver, inheriting from NSObject instead is all that we needed to do. It’s likely that this will be the same for you too.
If you run into any issues, or have any reason for us to delay removal of RMModelObject
, then please let us know as soon as possible.
If your plugin uses RMModelObject
, could you please reply to this post so that we know how many people this affects? If nobody is using it, we may remove it sooner.
