jbob
(jol yates)
October 18, 2018, 8:57pm
1
Hi
On my website I have a sidebar
And in that sidebar I have a PNG image with a link to the ‘press page’
(Most pages in fact have this image)
You’re still with me that’s good
So I publish and reopen the file the following day … and I think I’m going mad
The PNGs are all gone
So I replace them all
… and guess what happens next ?
Yes, the PNGs all disappear
Still with me ?
Ok - so the website is www.dibleymarine.com
The offending image is a .PNG of a stack of magazines
The beta is the latest (Oct 17th)
Themeflood 2.3 Boutique
Anyone any clues what’s going on here ?
Anybody had images just disappear ?
Many thanks,
Jol
jabostick
(Jason Bostick)
October 18, 2018, 9:02pm
2
The image disappears from your project or from the published website? Because I see the stack of images on your published site…
jbob
(jol yates)
October 18, 2018, 9:04pm
3
Sorry, to clarify - the image disappears from my RW file when I reopen it
(you’re seeing it gloriously freshly re-re-reinstated and re-published)
jabostick
(Jason Bostick)
October 18, 2018, 9:09pm
4
Ah gotcha - thought maybe it was a caching issue or something.
I can’t be of much help if it is project related. There is a thread here: Lost images when saving project after editing but it relates to RW 7. But perhaps an old bug crept back in to the beta…
jbob
(jol yates)
October 18, 2018, 9:21pm
5
Further - unlinked PNGs disappear on reopening the file
… as do JPGs
… and this has been going on for some time - not just the recent betas
Hope someone has an idea what might be happening here
Thanks, Jolyon
jbob
(jol yates)
October 19, 2018, 1:43pm
6
This is very easy to repeat - can anybody help me here
Just start a new project - start a stack page - use a v8 theme - drag a JPG into the sidebar
Then save it and quit the app
Open RW again and … where is your JPG
Is this a bug - or am I doing something stupid ?
Thank you
Jol
isaiah
(Isaiah Carew)
October 19, 2018, 4:34pm
7
@dan @tpbradley - i can repeat this as well
Bug report: Images in the sidebar do not persist correctly in any version of RW 8
To repeat:
New Project
New Styled Text page
Show inspector and switch to Sidebar tab (2nd tab).
With the small gear menu (which should really be a not be a min-sized icon since all other icons in the view are normally sized) choose “Styled”
Drag an image into the sidebar (type of image doesn’t matter).
Save and Quit
Re-open the same document and look at the same sidebar.
Expected Results: Image should have been saved.
Actual Results: (RW v8.0.x) An empty image border persists. But the image itself is not displayed.
Actual Results (RW v8.1.x) No image is shown at all.
Actual Results: (both versions) The image is stored in the file – in the resources directory of the file sandwich.
jbob
(jol yates)
October 30, 2018, 1:00pm
9
Anything happened with this - all my sidebar images still get deleted when saving
All RW v8’s
… just tell me you’re working on it ?
Aaron
(Aaron )
October 30, 2018, 9:35pm
10
This is actively being investigated and worked on. We hope to include the fix in one of our next builds. Thanks for your patience!
