When I was done with the effect, I moved the Snow stack into a Workman Locker stack and republished the page. The snow persisted.
Then I removed the stack entirely and republished the page. The snow persisted.
Does anyone know how I can remove this stack? By the way, this stack does not have turn on / turn off dates like some similar stacks so that is not an option.
So, even in the instance where I completely removed that stack and republished, does that remove any JS or CSS that would be associated with the Snow stack or do I have to somehow remove that manually?
Are you sure you removed all instances of the stack from the page? There may be a copy you missed or your publish didn’t actually publish the page. Try republishing that page if you find no copies left on it.
I see the snow on his page and I’ve never been to his site before, so it’s not cached.
Thanks to your responses, I was able to figure this out!
I did have 2 instances of the Doobox Snow stack. That is why when I removed (only one) and republished the page, the snow persisted. Somewhere along the way of cutting and pasting in an effort to remove, I ended up with more than one copy.
And Yes, Joe’s Let it Snow Stack is there as well. That stack will allow users to specify active dates, ie. when to turn on and off.
