Hello Joe, sorry if I bother you…
I have installed Seo Helper on my web site as you suggest; https://www.ev2go.it and I solved the double index issue, but now I have a duplicate meta tags alert. I don’t know why, I have unflagged robs metatag and description in every single page of my web site… but the alert still there… any suggest…?
<meta name="robots" content="index, follow" />
<meta name="description" content="Mobilità elettrica per privati eaziende">
<meta property="og:type" content="website"/>
<meta property="og:title" content="EV2GO"/>
<meta property="og:image" content="https://www.ev2go.it/PDF-COOKIE-PRIVACY/EV2GO%20-%20logo-banner%20EV2GO.png"/>
<meta property="og:description" content="Mobilità elettrica per privati eaziende"/>
<meta property="og:url" content="https://ev2go.it/"/>
<link rel="canonical" href="https://ev2go.it/" />
<meta name="description" content="EV2GO HOME PAGE">
<meta property="og:title" content="Mobilità elettrica per privati e aziende"/>
<meta property="og:description" content="EV2GO si occupa di mobilità elettrica per privati e aziende, sistemi di ricarica, wallbox, colonnine AC e DC ad alta potenza, vendita online di micromobilty e consuelnza su noleggio a lungo termine e vendita di auto elettriche."/>
<meta property="og:site_name" content="EV2GO"/>
<meta property="og:video" content="https://www.youtube.com/channel/UCfk-dDBFgg1rikFMJc5BbQw"/>
The page headers show duplicate robots, descriptions, og and canonical link.
Robots are controlled on a page by page basis on the pages page inspector (meta tags) on the right sidebar.
The og duplication can be controlled on the left hand sidebar under Settings -> General by turning off Generate Social Tags.
Also be sure there aren’t any meta tags defined on the code page.
@joeworkman has a nice video that shows this stuff titled SEO Helper Basics - SEO Meta Tags
Hi Rodney, thanks for your help, I did every step seen in the tutorial but I still have the advise…
see attachment:
The duplicates are being created inside your instance of the SEO Meta Tags stack. You need to remove the SEO Basics sub-stack if you are going to add all the other sub-stacks.
It works…! Thanks a lot.
I’m glad something I’ve done this morning was helpful to someone. It’s just been one of those days.
Sorry Rodney, another question: which is the specific stack that eliminates double indexes?
It’s built into the meta tags stack. You don’t need to add anything. The warning will show inside preview if it’s detected.
I turn my back and @joeworkman has to come in to save the day.
Hello Joe, I asked this becausemon my site after the advise I have canceled the index html with the button and everything work fine. On an another website, I have the announce from rapidweaver at the end of the upload, but no advise from your stack.
And you have your project website address setup properly?
You mean the correct web site address…?
Yes. You have to correct website address in the project General Settings and Publishing Settings.
There were 2 old index file on the ENG and DEU site, I removed them by ftp and now everything works fine. Thanks.
Joe, some days ago I have received a deal offer about all the stacks from Nick Cates from you.
So I assume that you have acquired the stacks as a developer. I already have the whole Nick package. I also use several Nick templates, as well as a mountain of your own and 1LD stacks. The question is: will you follow the development and update of Nick Cates stacks and templates…?
Thanks.
