When I add a flavicon and have the SEO helper stack installed I get the message:
You should disable meta tags, description and robots inside RapidWeaver if you are defining them with SEO Helper.
How do I do this?
How do I do this?
I turn this off and I still get the message:
? Thanks for your help.
I don’t have the SEO helper stack (new version). That’s the only way I know of to disable the meta tags?
You might try restarting RapidWeaver. If not @joeworkman?
Thanks.
You have to disable those on each page in the social settings
Thanks, I will investigate this.
I send a screenshot tomorrow, if you like, when I am on my Mac.
For SEO helper you will need to disable the ones above - all three of them. This will be taken care of by seo helper
Many thanks, all well now.
