Like to start a blog in my site. The theme selected does not have any.
Which is the easiest one for a novice?
Gracias in advance to all helpers.
Blogs are not part of the theme. You can add a blog to any theme by adding a blog page. The big question is whether you want to be able to add posts when you are not at the computer which you used to create the site. If you do, then you need some sort of add-on (of which there are many) which will allow you to blog from any computer or smart phone. Search http://rapidweavercommunity.com/addons/stacks for ‘blog’ and you’ll see what is available.
I’m using this solution to incorporate WordPress: http://www.cosmonio.com/blog/2015/03/14/tutorial-rapidweaver-foundation-wordpress-blog/ - works like a charm here: http://www.theconsultants-e.com/wordpress/ - still have to add a footer to complete the look, but it’s pretty easy to do.
Can always try Joe’s Tumblr stack, very easy to add to a stacks page, lets you update your blog from any computer or mobile device around the world.
Thanks to you guy. Your help is always appreciated. Also Gracias Aaron.
