I suggest the Icons on the left side of the Library Pop Up be able to have “user defined” text labels !!
Tim
Tim
This is something you would need to contact @isaiah and Yourhead about. It is a stacks setting, not a RapidWeaver setting.
@zeebe thanks for that info Robert, i would never have realised that in a month of sundays !
Fair comment under the circumstances
Tim
you can drag the split between the library icons and the library itself. there are labels! and they are user editable.
but i’ll take this as a feature request to make the existing feature more discoverable.
