Good news, episode 38 is out:
http://rapidweavercommunity.com/podcasts/the-rapidweaver-show/38
Hope you enjoy it. Happy Weaving!
Great episode guys, since you brought up the community site, I have a request of something that you can fix and add to that site. They both have to do with the release notes. If you click on the release notes link or the Whatโs new in version ?? link it looks like this:
Hmm, I just tested it and the pop-up appears in the middle of the pageโฆ
haha, no worries ![]()
Iโm already working on it!
Unfortunately not as the changes are too vast, and the code is tightly coupled to a lot of the new features in RW7.
If youโre running RW6 then your Mac should support the latest version of OS X - you should be able to upgrade.
Hope that helps.
Hmm, can you share a screenshot of that? The more information in that box, the higher the box goes, but it still seems attached to the bottom of the page. Also, do you have a bigger screen size? I am on a 13" MacBook Pro, so maybe that is the issue too. Here is another screenshot of Nick Cates Photo stack on the Community Page. It also appears the overlay background Opacity is not as opaque as it once was.
YEAH!!!
@ben Great call, I turned that off and it works! Thanks!! I do know about the Safari one and use it, but it was nice to be able to just click on a size I wanted to test on. But if that interferes then I will keep it off. I actually hardly test for that anymore anyways.
Thanks!
