Hi guys,
I would like to create a page in EPK (Electronic Press Kit) format within RW. Can anyone tell me the best stacks for a professional music player and for downloading JPG and pdf files?
Thanks in advance
Hi guys,
Thanks in advance
You might check out Paperless from stacks4stacks.
You really didn’t say what your “requirements” are.
But also from stacks4stacks checkout:
All the stacks4stacks stacks from @willwood have a free demo version so you can try before you buy.
This might help:
Thanks for your replies.
I’m trying to use paperless with RW8 to add documents for downloading.
Unfortunately I can’t solve this problem:
I created a folder that contains various documents in different formats. This folder has been inserted in the RW Resource to generate a path for a file directory.
When I try to insert in the general setting the address of the relative path it gives no result in the parpless stack. It remains empty when in reality I should see the list of documents.
What am I doing wrong?
Thanks in advance.
