Excited, however not working as expected
2021-03-29T06:00:00Z
Hello,
I recently purchased RapidWeaver - and have this environment - MacOS 11.2.3 Big Sur; Rapidweaver 8.8.1 (20868)
First Issue:
Decided to purchase STACKS 4 - got the bundle package. Stacks installs OK (I think), however none of the other plugins work?!?
When I start RW, I get the following errors:
  • Accordion: Couldn’t obtain plugin principal class
  • Blocks: Couldn’t obtain plugin principal class
  • Collage2: Couldn’t obtain plugin principal class
  • Flow: Couldn’t obtain plugin principal class
  • PlusKit: Couldn’t obtain plugin principal class
It also had an error for STACKS itself similar to the above, however after I registered it, I don’t see that error anymore.
UPDATE - it appears that the plugins are not universal - RapidWeaver 8.8 is now available as a universal build (read the second post)
Second Issue
I purchased Foundry v2, and that seamed to install OK
Downloaded Mason; clicked on it, and it appears to install OK
When creating a simple test page - adding Foundry Control Center then any Call-To-Action - whatever CTA I select looks weird (compared to the example videos), and when I unpack anything and click on it, this error shows:
  • Missing
  • Missing Stack Info
  • (null) Not Installed…
Is there an incompatibility here too, or am I missing something.
Thx for your feedback
Hi, for some mason templates you need the foundry add ons like potion pack. You can see these requirements on the mason site:
Force RW to run via Rosetta via its Finder info dialogue.
Thank you, Custard-Apple!
This is an extremely valuable hint - I had this issue and it’s solved now.
