Facebook Instant Articles
Hey, I’m wanting to know if Rapid Weaver is compatible with Facebook Instant Articles? According to FB they have a plugin/code string that you can include on articles within a wordpress site, but I don’t know if that will carry over to RapidWeaver. I’m not the most tech savy when it comes to web design stuff, so figured I would ask.
Thanks!
I don’t know of a plugin or stack that does that for you. WordPress is completely different platform.
Looking at Facebook documentation, it looks like they have a simple iFrame style imbed.
That would mean you should be able to do this in almost any site.
<figure class="op-interactive">
  <iframe>
    <!-- Include Facebook embed code here. Your Facebook embed code should contain both the "JavaScript SDK" and the "Embedded Post Tag" parts described at https://developers.facebook.com/docs/plugins/embedded-posts#add-code-manually -->
  </iframe>
</figure>
This is just HTML, so if you are using stacks you should be able to place the code inside an HTML stack.
I don’t have the Facebook code for any sample articles or I would test it out.
Awesome, thank you so much! I like RapidWeaver and before upgrading it on my new computer and starting on a new site I wanted to make sure instant articles would work. Sounds like they will!
