Hi there !
any way to make arborescent FAQ’s instead of multiplying the pages ?
I have no idea what you mean. Are you looking at a specific product? Or How to do something? Can you show an example?
here’s the example : the sub-FAQ closes immediately when you click on it
https://laconsultation.ch/FAQ/page-2/index.html
regards,
Aurelio
Yes, I see the problem now. I don’t know if there is a way around it for the FAQ2 stack. Have you contacted Doobox? I did try with the Ivy accordion stack (very similar) and what you are trying to do works just fine. I think it should work with FAQ2 but I’m not seeing an obvious way to accomplish your goal.
thank you !
i’ll check Ivy’s solution waiting for doobox to answer.
regards
