How can I set the reply to address to the Email Adress of the person, who just filled the form?
In that way I could just hit reply to answer incoming contact form mails.
I found the hint “You can use {{field_id}} templates with form field names in the above settings.”
Where to find further information about the field_id?
You have a text input stack in your form and you name it in the settings of this stack. Is this text input stack for an email, name it email. Then you can use this variable in the Form Base setting as the From Address with {{email}}
