Is there a way to search an entire site for certain words?
Bruce,
There is a handful of good search tools for RW itself - one updated only this weekend. That would be for your viewers.
But if you need to search for something you’ve placed and subsequently have to change, you could export the entire site/project to a local directory and use OS X’s built in Spotlight structure, restricting your search to that same export folder and its subfolders.
Yes, I’m looking for a way to search my site while working in RW. Seems like this is a wish list request.
If it’s for you, the Find on a page now works much better than it did in RW 5. Otherwise I guess your only option is the Export and Spotlight routine.
