Hi all, i am trying to restore some order to my Rapidweaver Projects, they are in a real mess, scattered about all over my hard drive.
I would like all my RW6 projects in one folder
and
all my RW7 projects in another folder
of course when i search for “.rw6” and/or “.rw” files in Finder, i get a lot of files that are nothing to do with either of those file extensions.
is it possible to search for specifically RW project files and nothing else ?? PLEASE
PS. i have a lot of .RWSW files, can someone please remind me what they are ? thanks
Best search tool out there is HoudahSpot. It’s fantastic. It seems Spotlight, if you put in “.rw” then it searchers for “rw” and ignores the period.
I don’t think I would buy HoudahSpot just for this immediate problem, but it is one fantastic piece of software. Oh, and of course, it will find all my “.rw” and “.rw6” files in less than 3 seconds on a 3 Tb drive.
The problem in this case is that you are using the “file extension” option. This isn’t really bad, but when you use this option is also means you do NOT need to use the period. Just put in RW.
Alternatively put “.rw” into the name contains option.
