Flashing in Preview mode
Hi, my screen keeps flashing in preview mode (RW6)
How can I solve this, or what causes the flashing?
This is a known issue if you are running High Sierra and RW6. Only RW7 is fully compatible with High Sierra.
You could try previewing in the browser if that’s the case.
Hi Neil,
Thanks for your answer. So I have to buy RapidWeaver 7 ???
As Neil (@NeilUK) pointed out, you can get by with previewing in a browser.
If you want to use the built in preview then RW7 is the only supported version.
