I have just replaced the built-in RW contact page with the above and I have to say that the flexibility it provides is very welcome.
However there is one question that I can not seem to find in the documentation (which is unusually well written by the way)
Question, In the captcha form, under Value choices I have entered Checkbox and left it ‘unchecked’ I am assuming that means that anyone sending an email needs to click and check the box for their message to be submitted???
However I have not entered anything in ‘option value’. is this important and if so what info does it require?
– Reply-To Item “item_2” has a value of “” which is an invalid email format.<br>This usually happens when you assign the incorrect Item Name to the Reply-To Item setting.
I switched off send receipt thinking that might stop the error messages, but it didn’t.
