Formsnap is working fine except that after hitting the send button a new blank form hides the success window. Only when that form is closed can the success window be seen.
This makes the user unsure whether the form has actually been sent.
Not sure whether this was happening before I started using Foundry or whether this is the way it is with Formsnap.
Or probably a setting I’ve got wrong.
As always, comments would be greatly appreciated
Mike from Yabdab has told me that the problem is that I have been using Formsnap in a Foundry Modal and the z values are conflicting. Not a Formsnap issue.
Link to page would be helpful.
