Hi RapidWeavers,
After a year of development, I am proud to take the wraps off of my latest stack, FormsPlus. FormsPlus allows you to build up a multi-step contact form or wizard for RapidWeaver. This is great for questionnaires, feedback forms, and more. That’s, however, not all. There is so much more to FormsPlus.
Upload styling
Easily customize the style of your contact form. Choose from 11 different layouts. All of which can be colonized to match your site.
All the Inputs!
All of the inputs are at your disposal. Everything from your standard text input to range inputs, date inputs and telephone inputs.
Range slider
FormsPlus have an awesome Range Slider designed by @willwood
Date picker
Need to collect dates? Need to restrict the date selection? No problem. The date picker is a new powerful tool for users.
Validation
Optionally validate an input as both required and type. For example, you can make an email required but also appear to be a valid email!
Templates
Want to send yourself an email when the form is filled out? No problem. Want to send a thank you to the user for submitting the form? No problem. Want to send a third email to the sales@ department? No problem! FormsPlus allows you define as many different templates as you’d like. Each template can do to any email address you prefer. Don’t want to use email? You can save the responses directly to your web host too.
Upload magic (e.g., WeaverBox)
WeaverBox was the only RapidWeaver plugin that support file upload chunking. This allowed WeaverBox to upload files up to 2GB without having to change anything on the server. Typical contact forms are restricted to 8 or 10MB.
I am happy to say that FormsPlus takes the same technology and improves on it. Not only can FormsPlus upload files up to 2GB, it also now supports mobile devices, groups uploads automatically by user, drag and drop support, and upload resuming.
Are you an owner of WeaverBox? Upgrade to FormsPlus for 50% off. Simply use the same email address that you used to purchase WeaverBox. Note that WeaverBox has now been discontinued.
For more information about FormsPlus and an online demo, please visit the product page. FormsPlus is available now via my online store for $29.95. Remember, WeaverBox owners get 50% off when they upgrade!
Your top dog,
Greg
