johannes
(johannes)
1
Hi to all
I want to rebuild the navigation for my website. But I dont know how he has done it.
built in Foundation / Top Bar
Layout fill mode : fill
menu bar : Center
now my question:
How I can define the same width size between the words(Pages) and
how to build the line below the navigation ?
Jo
tav
(Andrew Tavernor)
2
The equal spacing of the menu items is simply by with the Align setting set to Center
The “line” below is just a shadow - select the Shadow when fixed checkbox.
Other than that you just need to set the Position to Sticky and place it beneath your header.
