Dear RapidWeaver community,
does anybody of you know how to move the menu bar to the right and the title to the left? Padding/Margin is not an successful option (I tried it a few times and it didn’t work).
Thank you!
Thank you!
Hm, can’t understand what you mean. The title is on the left and the menu bar on the right by default. So what do you want exactly? If you want both to be right-/left aligned with the actual content of the site, simply put the Top Bar in a 1 Column Foundation stack. If you want the menu bar and title to stretch across the entire site, simply place it outside of a 1 Column Foundation stack.
I want to have the texts way more in the corners.
There is a TopBar option called Contain within body, uncheck that.
Thank you again for your support
