Foundry Navigation bar question
Using Foundry
How do I make the main navingation with a drop down clickable? Is it called the Parent link?
Parent level navigation items do not get linked in the Navigation Bar stack. This is purposeful choice on my part. Since the Navigation Bar stack is one of the most used stacks in Foundry I wanted to make sure it works well with older mobile browsers, so I opted to have the parent items act as a toggle for the drop down menus instead of a of link to a page.
Cool thanks. I thought something like that might be the case. Just wanted to check.
Foundry is amazing. Especially with Potion Pack.
Not a problem. You were right on the money then!
Thanks for the kind words. It really means a lot. Lots of other great things in the works for Foundry! :smiley:
Can’t wait! Where best to keep an eye on that? Twitter?
