Update: Transmit is not the problem. I have had errors with the Transmit application not running.
I have had the same FTP publishing problems since December. Sometimes even restarting RW did not help and other times, it would publish flawlessly. I thought it might be the server because it was a local, private server company. So I moved one of my sites to Little Oak and have not had a problem with that site since. My previous server’s admin was a PC guy and used Plesk and enom.com and there always seemed to be problems with them. I decided to go to a Mac friendly server. Of course, don’t know if the server was really the problem but I will probably be moving my other sites to LO if I continue to have problems with them.
Mary
I join the ranks , just to add to the forum. Same problem here.Fairly new to RW and have been struggling all day with this, thinking it was my mistake(s) that produced this. But it is totally random when it uploads successfully, although quitting and rebooting seems to help.Sometimes.
last updates of Rw and OSX. maximum uplads 3 or one does not make any difference.
I have the same problem, but restarting doesn’t solve it.
I cannot publish with Rapidweaver, I must export the entire site, so for a little change in one page, I must re-upload the entire site!!!
Can you solve this big bug?
I am having this problem and its driving me to despair
Can any one help ? - my website just will not upload and i am told this is rapidweaver problem . I am on Rapidweaver 6.8 and using photgraphos theme.
any suggestions ?
Hi. As I am encountering the same problem, with RW 7,5… How did you solve ?
I could never get it to work properly despite the multiple attempts at different solutions. I was able to reduce the frequency of errors by changing the “Mode” to Passive and “Connections” to the slowest level. However it was still frustrating. So I started uploading my site files via FileZilla and it worked everytime. It was a pain in the butt but it worked. Then I upgraded to RW7 and it worked everytime. Not sure why your having an issue with 7.5 but thats my experience with RW6
This is a very old post about a totally different release of RapidWeaver. In RW7 the entire publishing engine was rewritten, so I doubt any fix that works for RW6 would solve your problem.
I would recommend you go through this help article and if you can’t solve the issue, open a new post with details outlined in the article.
https://help.realmacsoftware.com/rapidweaver-troubleshooting/how-to-fix-ftp-publishing-issues
Thanks…; I will first try FileZilla…To be sure my accounts are valid…
Strange situation now… When I enter the IP address it is working… On all my previous works I never added this IP address, but the hostgator hostname…
Anyway… it works…
Assume you’re talking about server name? You didn’t by chance turn on CloudFlare?
Yes, servername… No idea what it is Cloudfare…
