Im trying to get google translate code working in stacks using the html stack but its not showing up-Ive also tried in blocks and an earlier version of RW but nothing-can anyone help please?
heres the code
I don’t see any code. …
… but I use Joe Workman’s free Translate stack. Works fine. More here:
HI Mathew The code didn’t load fro some reason. Meanwhile Ive had a tryout of Joe Workman’s free Translate stack and it perfect! Many thanks!
I believe the Google code needs to be divided up and placed in 2 different places. Part in the inspector area (HTML or Prefix) and another in the regular page. So that may have been the problem. At any rate, with Joe’s stack I don’t need to worry about those issues! Glad you got things going.
Yes I was wondering about the google code but there instruction are very simple and says nothing splitting the side up. Still Joe’s stack does the job fine for me many thanks
at the end if you have : script type=“text/javascript” src="//translate.google.com/translate_a/element.js?cb=googleTranslateElementInit"></script
try to add ‘http:’ or ‘https:’ before // and republish.
It worked for me.
Yes that did the trick many thanks! So I wonder why that got left out of the code? theres no mention to put it in. Many thanks for the your input
Fantastic! Thanks for the great tip! Worked like a charm!!!
