I’m using Foundry. How can I use a graphic of my choice for linked button?
It sounds like you just want to add an image of a button to the page, and link it, correct?
If so, drop a Foundry Image stack onto the page, place your button image in the stack and then use the Link option in the Image stack’s settings.
Not sure what you mean. I placed an image stack on a page, but I don’t see a link option.
click on the graphic…and the link button will show
Sorry this is for Stacks 4!
The link option is a part of the Image stack’s settings, here:
That setting is mentioned on the Documentation page for the Image stack, here: Image
Aha! It’s easy when you know what to do! Thanks!!
So unable to leave well enough alone, is there a way to add a hover image?
No, the stack doesn’t have a way to do that.
Thanks, anyway.
However, the Hover Image stack does. It’s available as part of the Potion Pack add on for Foundry.
No, Hover Image does not have a secondary image when hovered over. It provides a hover overlay on the image via CSS animation when hovered over.
Thanks. I’ve just purchased that pack.
As I mentioned above that stack will not do what you want, @robbeattie was mistaken.
My mistake, the Potion Pack Hover Image stack does not do what you want.
Oh well. If I pursue this idea, maybe I’ll use tool tips as a roll over.
