Im creating a site using Foundry.
I need to make a nav bar like this (Hover SHA Method in nav)
Any ideas !?
Any ideas !?
This is a super quick mockup, but you can do a navigation similar to that using the Potion Pack’s Mega Menu stack: https://d.pr/v/cE0DB4
If you want it limited a bit more to the center just use Mega Menu’s fixed width settings instead of the fluid setting:
Woah cool. Thanks Adam. I’ll try that right now!
Thanks Adam this is perfect. I hadn’t appreciated how much this stack could do.
Quick question. Can I loose the little chevron thing ^ (that sideways)
The drop down indicator icon you’re referring to does not have an option to hide it.
