We’ve seen more than a handful of these reports since launching 7.1 - We’re still trying to get to the bottom of it, but I’m suspecting they are just not running the latest version of Stacks.
There was an early beta of Stack 3 (I believe it was 3.0b4) that broke sparkle updates. I have seen many users stuck at that version. While using that version can obviously make things not work properly, I have never heard of it “bricking” anything. I bet this user is being a little melodramatic.
We put a check in on RW 7.1 to make sure it didn’t load earlier stacks aversion that aren’t compatible with 7.1 - as it had potentially to screw peoples sites up.
This probably explains it as most users should be up-to-date if they have a working sparkle feed,
I’ve seen two people with this issue (one who sent me 4 emails and two tweets – they were very thorough).
There was also a bug in the installer that allowed multiple versions of plugins to be installed if they had slightly varying names – and only one of them ever gets loaded by the app and updated. It’s a long shot, but this could explain the “I’m already running the latest and it still doesn’t work”
If you find a less irate customer to give you the details of their addons folder it would probably help to find the source of the issue.
Also… if anyone has a copy of one of these beta versions that doesn’t update for some reason, I’d really like to have a peek at it. Even just more specific version info would be super helpful.
I know that several people have ad the “i’m stuck on a beta” problem – but I honestly don’t know why. I have records of 3.0.0b3 and 3.0.0b5 but I have no record of ever releasing a 3.0.0b4.
b3 and b5 have totally normal appcast URLs and version numbers and update without issue.
After much scouring of my crashlogs I found that there was a significant bump on crashes that occur in Stacks 3.0.3 b4 – for some reason or another i always thought it was 3.0.0 b4 that was the hangup.
Anyway that version did indeed contain a busted appcast URL – oddly truncated. But with some amazing web server rewrite rules I was able to convince the server to deliver an appcast when that URL is hit.
Hopefully this will help clear up some of these issues.
