jspencer2
(Jonathan Spencer)
September 14, 2017, 7:39pm
1
I sure there is another thread about this somewhere but I think it needs to be brought up again. With the GM of High Sierra out and a roll out date of 25th September announced when will Rapidweaver be compatible with the new MacOS?
I was looking to buy a new Mac to replace my 2009 MacPro but as Rapidweaver is one of my most used programs I can’t until I am sure it will work properly.
teefers
(Doug Bennett)
September 15, 2017, 11:36am
3
I think (I didn’t beta test) there’s still an issue with the latest beta and RW.
Hi there,
I use RW7 on High Sierra Dev beta 2 (not on my daily driving Mac).
Once I preview a page (whatever the page type might be. RapidWeaver reloads the page and once it is done it start reloading again. I that something you experiencing to?
I have seen this still being reported as at least one problem.
teefers
(Doug Bennett)
September 15, 2017, 6:45pm
4
If someone is beta testing High Sierra the GM release is available. That should be what is going to be the first live release.
I don’t geta test the OS so if one of you RW users who is beta testing might want to give it a try.
jspencer2
(Jonathan Spencer)
September 15, 2017, 9:05pm
5
Nope, I have tested the High Sierra GM with the latest beta of Rapidweaver 7 and it still loops the preview.
LaPan
(Brian LaPan)
September 16, 2017, 12:27am
6
It’s an APFS issue that’s mentioned here. A fix is upcoming
We've been working on RapidWeaver 7.5 for some time now, and while we're not yet finished with it, we wanted to get it into your hands as soon as possible for testing. Our plan is to release the final build of RW 7.5 when High Sierra launches later
jspencer2
(Jonathan Spencer)
September 16, 2017, 9:51pm
7
I have just updated to 7.5 which is said to have a workaround to the preview problem but it is still there!
Steve
(Steve)
September 19, 2017, 5:25pm
8
The preview problem is still there for me as well. I’m running the High Sierra GM and RW 7.5
I’m hoping Realmac releases a new 7.5 beta soon, with a workaround or a fix. The commercial release of High Sierra is in only 6 days.
dan
(Dan)
September 19, 2017, 10:13pm
10
Yup, still working on it. We made good progress today, expect a beta soon!
dan
(Dan)
September 20, 2017, 4:49pm
11
Okay, here’s an unofficial beta, this new build should fix the constant refresh on High Sierra:
https://dl.devmate.com/com.realmacsoftware.rapidweaver/18784/1505925844/RapidWeaver-18784.zip
thanks a lot dan. at least for me on a 2017 macbook pro 15" and the gm build it does indeed bring back preview without looping
TINO
(Stijn VC)
September 20, 2017, 5:48pm
13
Yes indeed it does bring back preview without looping
jspencer2
(Jonathan Spencer)
September 20, 2017, 7:27pm
14
Woo Hoo, it’s fixed the preview problem for me. Thanks, I’m sure it was a simple fix and not you guys burning the candle at both ends…
handshaper
(Robin Mair)
September 20, 2017, 8:11pm
15
Yippee! Fixes it for me, really been needing this, made my day as I have some updates to test, thanks!
wvillers
(William VILLERS)
September 21, 2017, 5:53pm
16
7.5.1 works wonders on HS, no more preview flashing… Nicely done @dan & co
