How do I change font for nav bar pro
Hi, so im trying to edit the font for my nav bar pro, trying to change it to sobachka regular but im having trouble finding how to correctly do it. Could someone help me out? Thank you!
I assume you’re using Foundry?
If so, you’re going to want to check the comprehensive documentation and watch the accompanying videos for the Typeface stack which walk you through from start to finish.
Once you’ve got Typeface set up correctly, it’ll be as easy as selecting ‘Typeface x’ in any component stack.
