Complete newbie here, and not sure exactly where to ask this question. Here’s my setup: RW 8.7, Stacks, Foundry (using Foundry theme), Font Pro. I’m trying to modify the default styling of text used in the Markdown Text stack. There are obviously definitions for heading 1, heading 2, etc., but where can I go to modify them?
Google for markdown text styling, here is a starter for you.
Thanks! I saw a screenshot of a similar page, but this has a lot more detail. I’m still wondering where the definitions can be edited. Probably hiding in plain sight… just trying to learn my way around RW.
You just type the markdown formatting characters in with the text.
If you want to set particular fonts for parts of the text, you will have to resort to html in the text/markdown stack.
Go grab MacDown…makes markdown easy.
If you’re using Foundry, then the settings for heading and paragraph fonts/styles are set in the main Foundry stack you need on each page. Also, you may want to try using Typeface (part of Foundry) for your fonts. You likely don’t need Font Pro.
