How do I Show a page in site map but not in navigation SOLVED
I am looking for a way to have several pages that show up in my site map but not in the navigation. I am currently using Sitemap Plus but when I remove a page from navigation I can not “uncheck” hide in site map.
Any ideas?
@swilliam
Manually create your Sitemap using Stacks, use the previously generated sitemap.xml as an example to build your own for your custom Sitemap?
Brad
Thanks for the reply @Turtle,
I had hoped to hear that another site map solution would work or there was a way to do it in Sitemap Plus. I’m not really sure why it would not let the user decide to include a page not in navigation, it lets you exclude one that is… Maybe @isaiah will stop by this thread with some wisdom to share :slight_smile:
Scott
Okay in an effort to help others…
If you un-check Hide pages marked “Don’t show in Menu” you can then decide for your self which do and don’t show up.
@swilliam, This is a configuration setting in SiteMap Plus correct?
Brad
correct - (and the rest of the needed characters)
Thanks for sharing @swilliam
Brad
